609.450 aktive Mitglieder*
5.832 Besucher online*
How Is Anodizing Masking Achieved?, How Is Anodizing Masking Achieved?
Beitrag 18.01.2026, 12:43 Uhr
BANkok
Anodizing is a widely used surface treatment process for aluminum and its alloys, enhancing corrosion resistance, wear resistance, and aesthetic appeal. However, in practical production, certain areas of workpieces (such as threads, holes, assembly surfaces, or precision mating parts) often need to be protected from anodizing. This protection is achieved through anodizing masking—a critical step that ensures product functionality and processing quality.
Anodizing masking methods are selected based on workpiece shape, size, surface complexity, and production batch, with four commonly used techniques in industrial applications:
Adhesive Masking Tapes
Made of high-temperature and chemical-resistant materials (e.g., silicone or polyimide), these tapes are ideal for simple shapes like holes, edges, and flat surfaces. They are easy to apply and remove without leaving residues, making them suitable for small-batch production or prototype machining.
Silicone Plugs/Caps
Custom-machined to match the size of holes, threads, or protrusions, silicone plugs/caps offer excellent resistance to anodizing electrolytes and high temperatures (up to 200°C). They provide tight sealing, preventing electrolyte penetration and are reusable, suitable for batch production of parts with standard-sized holes.
Masking Liquids/Paints
These are specialized coatings that form a tough, peelable film after drying. They adhere well to complex curved surfaces, irregular contours, or narrow gaps that tapes or plugs cannot cover. After anodizing, the film can be easily peeled off or cleaned with solvents, ensuring no damage to the workpiece surface.
Mechanical Masking
Using clamps, fixtures, or protective plates to physically cover large areas or specific regions. This method is stable and repeatable, making it suitable for mass-produced workpieces with consistent masking requirements (e.g., large structural components or assembly surfaces).
Partial masking is widely used in product design, primarily for meeting aesthetic requirements or localized conductivity needs. If you are seeking a cooperative partner with extensive experience in partial masking processing and have custom products requiring fabrication, please feel free to contact us!
For more surface treatments and component machining requirements, please visit us here!
Der Beitrag wurde von BANkok bearbeitet: 18.01.2026, 12:43 Uhr
