608.391 aktive Mitglieder*
2.236 Besucher online*
Problem with Maho MH600W philips 532
Beitrag 21.12.2018, 08:39 Uhr
ndmisiek
Hello.
At the beginning I wanted to apologize for my "English"
I need help.
I have a problem with the maho mh600w machine on the Philips 532 control machine lost the machine steels stored in the bios.
No service in Poland wants to be repaired, my only hope is that one of you has the same machine and could read this data and help me.
Best wishes
Simon
Der Beitrag wurde von ndmisiek bearbeitet: 21.12.2018, 08:39 Uhr
Beitrag 21.12.2018, 11:54 Uhr
mtronik-kit
QUOTE (ndmisiek @ 21.12.2018, 08:39 Uhr) *
Hello.
I need help.
Best wishes
Simon
Hello,
have you replaced the battery on the EPC-8 ?
best regards
mtronik
Beitrag 27.12.2018, 08:53 Uhr
ndmisiek
QUOTE (mtronik-kit @ 21.12.2018, 11:54 Uhr) *
Hello,
best regards
mtronik
Hello,
Yes I replaced the battery, but I do not have a fixed machine so I ask if anyone could help me.
Beitrag 27.12.2018, 11:36 Uhr
mtronik-kit
QUOTE (ndmisiek @ 27.12.2018, 08:53 Uhr) *
Hello,
Hello,
here your EXM configuration
Slot 31: FD 01 00
Slot 0: FD 00 00
Slot 1: F7 A1 11
best regards
mtronik
Beitrag 27.12.2018, 16:06 Uhr
ndmisiek
QUOTE (mtronik-kit @ 27.12.2018, 11:36 Uhr) *
Hello,
Slot 31: FD 01 00
Slot 0: FD 00 00
Slot 1: F7 A1 11
best regards
mtronik
Hello,
Thank you very much for the EXM configuration, the error associated with it has disappeared.
However, the system does not start any more.
Do I have to set up the disk in Bios?
If so, how?
Best Regards
Simon
Beitrag 27.12.2018, 17:57 Uhr
mtronik-kit
QUOTE (ndmisiek @ 27.12.2018, 16:06 Uhr) *
Hello,
If so, how?
Best Regards
Simon
Hello,
I have the other settings here
best regards
mtronik
Beitrag 28.12.2018, 12:36 Uhr
ndmisiek
Hello,
Thank you very much for the help the system has started.
However, there was a problem with the fact that the keyboard from the PC must be connected all the time because it does not want to start.
another problem is that the machine does not want to be stressed. The X axis switches off the limit switch. (error x04 max following error too large)
Is it possible that the machine constants have been deleted?
I will add that before the failure everything was ok.
best wishes
Simon
Der Beitrag wurde von ndmisiek bearbeitet: 28.12.2018, 12:43 Uhr
Beitrag 28.12.2018, 12:55 Uhr
mtronik-kit
QUOTE (ndmisiek @ 28.12.2018, 12:36 Uhr) *
Hello,
best wishes
Simon
Hello
The machine parameters have been deleted and must be entered again.
Because of the keyboard I have to check. there is another wrong parameter in the bios
best regards
Beitrag 28.12.2018, 13:03 Uhr
ndmisiek
QUOTE (mtronik-kit @ 28.12.2018, 12:55 Uhr) *
Hello
best regards
Hello,
Do you have any parameters? unfortunately, I got documentation for my machine matching Maho 800 sad.gif
best regards
Simon
Beitrag 28.12.2018, 13:15 Uhr
mtronik-kit
QUOTE (ndmisiek @ 28.12.2018, 13:03 Uhr) *
Hello,
best regards
Simon
I need the exact configuration of the machine.
But it is very difficult to get the right parameters. it is better to ask the pre-owner of the machine.
best regards
mtronik
Beitrag 28.12.2018, 13:26 Uhr
ndmisiek
QUOTE (mtronik-kit @ 28.12.2018, 13:15 Uhr) *
best regards
mtronik
I just talked to the previous owner of the machine unfortunately does not have such data.
What information is exactly needed?
regards
Simon
Der Beitrag wurde von ndmisiek bearbeitet: 28.12.2018, 13:27 Uhr
Beitrag 28.12.2018, 13:41 Uhr
mtronik-kit
QUOTE (ndmisiek @ 28.12.2018, 13:26 Uhr) *
regards
Simon
Where's the machine?
You have not entered anything in your profile.
Beitrag 28.12.2018, 13:53 Uhr
ndmisiek
QUOTE (mtronik-kit @ 28.12.2018, 13:41 Uhr) *
The machine is in Poland near Krakow.
in my opinion, the machine has in the machine constants currently entered a larger range of work in the X axis.
Beitrag 28.12.2018, 14:15 Uhr
mtronik-kit
after switching on the machine you have an error O23 ?
Beitrag 28.12.2018, 14:34 Uhr
ndmisiek
QUOTE (mtronik-kit @ 28.12.2018, 14:15 Uhr) *
after switching on, error I01 appears after starting the machine, there is no error.
the ruler (heidenhain) gives a reading in the range of 450 but it is turned off by the limit switch and does not reach the RF point
Der Beitrag wurde von ndmisiek bearbeitet: 28.12.2018, 14:49 Uhr
Beitrag 28.12.2018, 15:11 Uhr
mtronik-kit
QUOTE (ndmisiek @ 28.12.2018, 14:34 Uhr) *
The parameters have to be checked.
you have to ask MAHO for the original parameter.
Beitrag 31.12.2018, 11:23 Uhr
ndmisiek
QUOTE (mtronik-kit @ 28.12.2018, 15:11 Uhr) *
hello.
the problem of machine constants has been solved.
there is now a problem after changing the language to English mc memory checksum error appears.
and I can not connect to the machine using the nclink rs 232 program, does anyone have a connection diagram and what data needs to be changed in machine constants?
Regards
Simon
Beitrag 03.01.2019, 08:20 Uhr
ndmisiek
QUOTE (ndmisiek @ 31.12.2018, 11:23 Uhr) *
hello.
Regards
Simon
Hello,
At the beginning I wanted all readers to wish all the best in the new year!
Small update:
I received machine constants from Maho, however I can not connect to the machine via the RS232 port. I use NClink software.
Can anyone help me how to set the machine and how should the configuration of the cable to connect look like?
I use a cable that communicates with the machine on the 432 control but all the time after downloading data from the machine receives a square sad.gif and you can not send out.
below the cable configuration.
Please help.
Regards
Simon
Der Beitrag wurde von ndmisiek bearbeitet: 03.01.2019, 08:27 Uhr
Angehängte Datei  20190103_082503.jpg ( 156.27KB ) Anzahl der Downloads: 26
Beitrag 04.09.2025, 22:19 Uhr
NenadMijajlovic
Hello everyone,
Could someone please share the machine parameters (machine constants) for a MAHO MH 600W with a Philips 532 control unit?
I need these parameters to restore the machine after settings loss. Any help—screenshots, text files, PDFs, or photos of the “Parameter Screen” values—would be greatly appreciated.
Thank you in advance!
